Postbank Giro Fehler
PAP
Gepostet: 15.05.2013 - 16:16 Uhr  ·  #1
Es wir bei mir eine Fehlermeldung ausgespuckt sodas ich keine Überweisungen tätigen kann.
<16:05:09.786> adding job Ueb5 to dialog
<16:05:09.826> executing dialog for customerid XXXXXXXXX
<16:05:10.941> processing dialog init
<16:05:10.962> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.version=2
<16:05:10.969> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.method=PIN
<16:05:10.979> creating a connection to https://hbci.postbank.de:443/banking/hbci.do and checking the certificate
<16:05:11.006> waiting for response
<16:05:11.023> message has no signature
<16:05:14.977> processing jobs
<16:05:15.001> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.method=PIN
<16:05:15.027> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.version=2
<16:05:15.044> waiting for response
<16:05:15.060> HBCI error code: 9050:Teilweise fehlerhaft.
<16:05:15.077> HBCI error code: 9010:Verarbeitung des Auftrags abgebrochen. (3: CustomMsg.GV.Ueb5)
<16:05:15.093> HBCI error code: 9210:Kontonummer oder BLZ falsch (3: CustomMsg.GV.Ueb5)
[<16:05:15.126> message has no signature
<16:05:15.147> HBCI error code: 9010:Verarbeitung des Auftrags abgebrochen. (3: CustomMsg.GV.Ueb5)
<16:05:15.167> HBCI error code: 9210:Kontonummer oder BLZ falsch (3: CustomMsg.GV.Ueb5)
<16:05:15.197> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.method=PIN
<16:05:15.210> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.version=2
<16:05:15.228> waiting for response
<16:05:15.248> HBCI error code: 9050:Teilweise fehlerhaft.
<16:05:15.277> HBCI error code: 9160:Nicht belegt. (3:6: CustomMsg.GV.TAN2Step5.orderref)
<16:05:15.294> message has no signature
<16:05:15.310> HBCI error code: 9160:Nicht belegt. (3:6: CustomMsg.GV.TAN2Step5.orderref)
<16:05:15.334> HBCI error code: 9160:Nicht belegt. (3:6: CustomMsg.GV.TAN2Step5.orderref)
<16:05:15.361> processing dialog end
<16:05:15.383> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.method=PIN
<16:05:15.402> could not insert the following user-defined data into message: Crypted.CryptHead.SecProfile.version=2
<16:05:15.418> waiting for response
<16:05:15.433> message has no signature
Beim Konto Aktualisieren kommen auch immer diese Zeilen vor:
Seltsamer Weiße werden die Buchungen aktualisiert.
Postbank Giro
Pecunia 1.0 (1.0.3)
Mountian Lion 10.8.3
obnutzer
Re: Postbank Giro Fehler
Gepostet: 15.05.2013 - 16:34 Uhr  ·  #2
Die Postbank hat im Moment ein techn. Problem. Im Subsembly Unterforum gibt es einen Screenshot davon. Könnte hiermit zusammenhängen.
PAP
Gepostet: 16.05.2013 - 08:15 Uhr  ·  #3
bei Konten von der Spasskasse kommt auch folgende Meldung:
Was mach ich falsch? Meiner Meinung nach ist alles Korrekt eingegeben.
Danke im voraus.
Gepostet: 16.05.2013 - 23:54 Uhr  ·  #4
Diese "could not insert the following user-defined" Warnmeldungen kann man in aller Regel ignorieren. Die stammen von HBCI4Java. Eigentlich koennte ich das Level dieser Meldungen mal von "Warnung" auf "Info" oder "Debug" herabstufen - eigentlich irritieren diese Meldungen nur. Wichtig sind die roten Fehlermeldungen. Und hier siehe obnutzer's Posting.
PAP
Gepostet: 17.05.2013 - 08:37 Uhr  ·  #5
Danke für die Info.
Irgendwie klappt es jetzt doch nachdem ich alles neu eingegeben habe.
